MVVS 152
#51
RE: MVVS 152
Thanks, very interesting. Does the motor use the same standard mufflers I'm using on my 116. I think they 58 mufflers as well. PE is the user manual avaliable for download yet. Also looking for the bolt pattern.
#52
RE: MVVS 152
The 3204 mufflers work well. Main dimensions and bolt patterns are identical with the 116
[link=http://www.mvvs.nl/MVVS/images/MVVS152.pdf]Get the dimensions drawing here.[/link]
There is not yet a manual on line.
[link=http://www.mvvs.cz/docMVVS/116/EN%20116cc.pdf]Klick here [/link]for the 116cc manual
#53
RE: MVVS 152
Incredible, thanks managed to download same. Ill be back in Cape Town around 18th -20 April, so if you have the motor by then please sent it. Do you still have my address. I think it was on the payment that I sent through the other night.
Gary
Gary
#57
RE: MVVS 152
ORIGINAL: wifpwcf
thanks for the info pe ,The mvvs motors are great.
i will email you details
cheers glen
ORIGINAL: pe reivers
I just called MVVS. I can pre-order, but no more than that, because the engine is still in pre-production test stages and not finalized.
Next week in NĂĽrnberg we will learn more.
Probable release sequence: 152, 80, 50. Do not expect the 152 to be available before April, and the 50 will not be available before august. These things can't be rushed. Too many small things can go wrong.
Please mail me your personal data if you want to place a pre-order. No strings attached until I placed the order with MVVS.
cheers glen
Latest news:
Plans are confirmed. The cylinders will be available by the end of the month. Expected delivery of 80cc and 152cc will be at mid August
#59
RE: MVVS 152
Latest update.
The 152 is delayed again due to cylinder delivery shortage. Only a few cylinders were delivered, and most went into 80cc engines (quality takes time)
MVVS tries to get one engine 152 through to me, but more likely it will be late october.
80cc engines are available. I have them in stock.
