EVO 26GT - old style
RE: EVO 26GT - old style
Yes, of course there is.
take out the lower plug boot and fit the plug in it. Assenble the HT cable with upper boot over the plug. keep making contact between plug boot and engine, and check away as much as you need!
Thank you for your response. That is what I intended to do but was told that it would somehow destroy the ignition module. Thanks again.
Hello again,
OK, I have no spark. My igition battery 4.8V is fully charged at 5.1V. What is supposed to be inside the spark plug boot? When I look in there I see a small spring and that is all. Is something missing in there? If not, I guess I will need a new iginition module. Is the only one that will work the EVO brand from Horizon Hobbies or do others work?
Thank you.
Thank you.
That small spring is all you should see.
The old ignitions are no longer serviced. If you want to replace it you will need the new ICU and drive washer that goes with it.
However:
The ignition being dead can be due to the hall sensor. Get a Hall sensor for a DL engine, splice it in, and see if you get a spark. Much cheaper than replacing the complete ignition. If that fails, well, you tried!
However:
My Feedback: (18)
IN
ORIGINAL: pe reivers
However:
However:
Before you go cutting up your Hall sensor cable check to see if you have continuity across the plug lead and ground. You will need an Ohm-meter, and all you have to do is measure between the contact spring and the metal boot case. The meter should read approximately 2 to 3 meghoms. The old ignitions use a cooper core HV line with a 3 meghom resistor. The resistor is embedded inside the cable just were it joins the boot and one end is inserted inside the copper wire while the other end makes contact with the contact spring. Sometimes the resistor looses contact with the copper core due to corrosion, and or breaks at the spring end.
If you find the HV cable to boot connection is open the folks at [link=http://www.ch-ignitions.com/]C.H. Ignitions [/link] sell a very nice fully shielded spark plug boot kit for 10mm (NGK CM6) plugs. They also carry a single cylinder ignition which sells for $79.95 versus $185 for an Evolution module. I believe their new ignition kits for the Evolution 26 come with the Hall sensor that mounts directly to the crankcase. In the past you needed to grind off the mounting flat on the crankcase and install the sensor with a metal strap. If your engine have a single magnet in the drive washer I don't think you need to modify the washer, but is better you phone C.H. to verify this information.
the single magnet and double magnet drive washer have the same polarity for the magnet that fires the ignition. The second magnet has a reversed polarity and will not fire the RCexcl or CH ignition.
CH makes a drive washer with their set that replaces the old washer, just like MVVS does in their upgrade set (which is not 185 dollars!)
My Feedback: (18)
IN
I was not aware of an upgrade from MVVS and I am very much interested in purchasing a new Ignition assembly for a 45GX. Could you publish a link for the MVVS upgrades? Thank you.
My Feedback: (18)
IN
I have the link in every message I write.
I own an Evolution 45GX (MVVS 45IRS-MG) which I believe has the older Vlach ignition. The current ignition broke and I repaired the best I could but I don't think is fully reliable. If I replace the Vlach ignition with the new ICU ignition; Do I need to replace the drive washer?
Since the Mobil 2T Racing oil is no longer available in the U.S.A.; Can you mail Putoline oil to the states without too many import regulations and added cost? I sure appreciate any help you may be able to provide since Evolution support from Horizon Hobbies here is very poor to say the least. Thank you in advance.
I still have a supply of the original MVVS oil, which in fact it the Mobil 1 two stroke racing oil, mixed and colored red for MVVS. The Putoline line is a good and lower cost alternative.
For deliveries outside the European community I do not charge VAT (sales tax). I also believe the US customs does not charge anything on toy parts (the way I ship items), but if they do, that is out of my control. I keep all my activities legal, and normally do not answer any questions regarding reducing customs load. Every citizen has his own responsibility here.
My Feedback: (18)
IN
My Feedback: (18)
IN
For US citizens, there will be no customs hassle. The postman brings your orders right to your doorstep. You sign for receipt and that is it.
