MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
MVVS 35CC MSR Ignition LED
Old 07-19-2009, 04:19 PM
gsmith6879
My Feedback: (37)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default MVVS 35CC MSR Ignition LED
During a hard landing, OK it was a crash, one of the pins on the LED that provides an indication of how the MSR ignition on my MVVS 35cc gasser is working was broken off. Can anyone tell me what the specs are for this LED? I'm sure it a standard LED but I can't find any markings on the LED.
gsmith6879 is offline
Old 07-20-2009, 12:04 PM
pe reivers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: MVVS 35CC MSR Ignition LED
Any LED should work OK.
Having said that, You may want to check the ignition output Voltage to the LED first. Be sure to have about the same impedance (resistor load) as your replacement LED when measuring, or your measurements will be way off. There probably is a resistor cirquit inside the ignition placed in series with the led.
pe reivers is offline
Old 07-20-2009, 07:19 PM
gsmith6879
My Feedback: (37)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I kind of though one from Radio Shack should do. I'll check the voltage and see what I can find locally.
Thank you.
Old 07-21-2009, 05:55 AM
pe reivers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gains, you will see easy enough if it works. If the led burns too bright, put a 2K resistor in series.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
