MVVS 58 Limited Edition
GA
I just saw this engine on the MVVS website. This has to be the best 58cc gas engine available and the best looking. Does anyone have one of these? I would like to see a video of it running. I have Evolution and MVVS (26-58cc)engines and they all have performed great. I used the break-in procedure and the synthetic oil recommended in the manual. I don't know what plane I would put it in at this time, but whatever it is I think it will have this engine. I have a 30%(or 72 inch length) size limit because of transporting the planes to the field.
Here is the website: http://www.mvvs.nl/
George G. Royal
George G. Royal
RE: MVVS 58 Limited Edition
That is my website BTW, and I have them in stock
The engine is a pimped prosport. Technically identical in everery aspect. 200 have been produced by MVVS (Czech republic) as a special batch. Numbers are assigned when delivered to customers, who also can ask for a specific number (if still available)
GA
I really like the newer MVVS and Evolutions engines that use CM6 spark plugs. I have not had any trouble so far. I use Mobil 1 Motorcycle Racing 2T synthetic oil for now. I will have to switch to something else when I can't find it, but that will be a while. The engines I have run between 160-180F and I check the temp often. Maybe it is a special paint that dissipates heat. I just think it is a cool looking engine. Some painted engines look better than others. I have a MVVS 26 (red) and a Evolution 26(blue) with painted (anodized) heads. Maybe someone will take some temperature readings and post them.
ORIGINAL: octanehuffer
I thought painted engines retained heat.
MVVS engines have no paint whatsoever, and use anodizing (A chemical aluminum oxide conversion) to achieve the colors they want.
