RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   MVVS Support (http://www.rcuniverse.com/forum/mvvs-support-322/)
-   -   MVVS 40cc oil (http://www.rcuniverse.com/forum/mvvs-support-322/9129234-mvvs-40cc-oil.html)
JIMMYMUGUREL 09-28-2009 04:19 AM
MVVS 40cc oil
Hi Mr. Pe Reivers
Because the Mobile 1 2T Racing isn't being produced anymore,can I use Motul 800 without any problems? Is it of any importance if I Motul 800 RR or OR? Which do you recommend?
These types of oil are easy to be found in my town. In Romania I can find Putoline oil but I have to order it and wait a couple of days.
I've seen about all you can see on this forum about Motul 800, I need a last confirmation, because the engine is new and does not want to lose my warranty for it.
Thanks.
Regards,
Mugurel
pe reivers 09-28-2009 05:42 AM
RE: MVVS 40cc oil
At one time in the past, MVVS has confirmed that Motul 800 was a good oil to use in their engines.
However, Mobil 2T oil still is available from MVVS, and I keep some in stock as well as long as MVVS will supply it to me.
JIMMYMUGUREL 09-28-2009 08:04 AM
RE: MVVS 40cc oil
Thanks for the reply, I use Motul 800 is the best way for me even if it is more expensive than Mobil 1.
Regards,
Mugurel
JIMMYMUGUREL 10-05-2009 12:26 PM
RE: MVVS 40cc oil
1 Attachment(s)
Hello Mr. Pe Reivers,
In the end though I found Mobil1 Racing. The problem is that it has another design, different color (red) and another smell. I put a picture. The rest is the same that is JASO / FC. You know this new package? It is the same oil? Thanks for your help.
Best regards,
Mugurel
pe reivers 10-05-2009 04:29 PM
RE: MVVS 40cc oil
The Label is the same as the oil I have in stock. Oil colour in my stock is red, but that is a dye issue. Oils in this class have a very non-distinct colour, and are dyed to personalize/recognise them.</p>
JIMMYMUGUREL 10-22-2009 12:10 PM
RE: MVVS 40cc oil
Hi,
today in Romania the weather was good,20 degrees.In these conditions I and my friend Jimmy managed to running in my MVVS40 CC. We made this operation like in the manual. After 20 minutes I obtained 7200 rpm with a propeller Graupner G Sonic 20x10. During the running in I opened ''high'' with 1/2 spin. I used muffler 3271. After this period all the starts were at first or second spin of the propeller. The gas I used was OMW 95 Octane and the oil was Mobile 1 2T Racing full synthetic. For a start,I think it was a good result.
MVVS are the best, they produce excellent engines.
Finally thanks for your help Mr. Pe Reivers.
Best regards,
Mugurel
pe reivers 10-22-2009 01:56 PM
RE: MVVS 40cc oil
You are welcome.
JIMMYMUGUREL 10-22-2009 11:13 PM
RE: MVVS 40cc oil
Hi,
and a short movie.
Regards,
Mugurel
http://www.rcvideo.ro/media/161/MVVS_40ccm_benzina/
