NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
CMP T-45 ETA Landing gear?
Reply
Old 11-12-2010, 08:43 PM
mixxerx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default CMP T-45 ETA Landing gear?
Hi, when will you guys be carring those struts for the CMP T-45. Or maybe you guys won't have them at all like the F-4 [] I really love my new CMP T-45 BUT it really needs to have those struts. Please give me some info on these what are the ETA on them?
mixxerx@yahoo.com
Danny
mixxerx is offline
Old 11-24-2010, 06:49 PM
Herb H
Herb H's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CMP T-45 ETA Landing gear?
I posted this in the Nitroplanes support forum :
You people (CMP and Nitroplanes) really need to improve the packaging of the T-45 !!!
Mine was in fine shape, but just by a miracle.
The box needs to be stuffed full with bubble wrap and/or chinese newspapers, it's not enough to just tape one part to another (eg tape canopy to fuselage), both could get damaged !
You need to properly fill the box with newspapers, and separate parts so they don't rub on each other !
And ... do not send out kits before you have checked that the contents is not damaged.
It's such a nice kit and so much work has been put into it ... It's a real shame if it gets damaged in transit !
Please take note !!
Herb H is offline
Old 12-27-2010, 05:31 PM
Herb H
Herb H's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mina has flown, more details here:
http://www.youtube.com/watch?v=ya-FpxfVT1k
http://www.rcgroups.com/forums/showt...1336098&pp=100
HWH
Herb H is offline
Old 12-28-2010, 11:05 AM
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Herb H
I've purchased more than four dozen planes from NP and have had only three minor issues related to packaging.
Most of the inner boxes are shipped in much heavier outer shipping boxes which take most of the abuse.
Each part is individually wrapped and packed in foam padding and plastic outer wrap to prevent damage in case anything rubs...
That said, IMHO you are not wrong.
I just received the EP P28 ( are BARGAIN of a plane for $99.00!!! )... and found that the rudder mounting tab was broken ( fortunately cleanly ) at the rudder base.
This occured because the rudder was affixed to the top of one of the wings, packed UNDER another.
The wings were immobile, but the postion of the rudder caused it to break when the boxes were stacked in shipment.
While this was/is an almost trivial fix, it would have been nice if the packager had moved the rudder into a more protected area of the box.
FYI:
Experience tells me that I DO NOT want someone going through and "checking" the box contents, except maybe to just remove the cover and give it a superficial glance.
Having someone actually move off the taped up materials, typically results in a LOSS of small parts that may have come loose during shipment.
I prefer to find all of the necessary pieces in the box.
opjose is offline
Old 12-28-2010, 11:17 AM
Herb H
Herb H's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: opjose
... Each part is individually wrapped and packed in foam padding and plastic outer wrap to prevent damage in case anything rubs...
No, it is not. That was the point of my post.
Herb H is offline
Old 12-28-2010, 11:35 AM
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
From what I can see in your photo, the major parts are individually wrapped in foam then plastic.
You have a loose control surface, but that is normally taped with the others to interior packing material within the box, to keep it from flopping around.
You've removed the upper wing cardboard sheet too.
opjose is offline
Old 02-07-2011, 06:05 PM
steph280
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The issue with mine was the whole canopy hatch assembly came undone by the tiny crap tape they used, and then banged around inside the box which cracked the canopy itself, and dinged the intake tubes and chipped the fuselage. All it takes is one lose piece to break everything around it.
Consider yourself lucky if your plane arrived undamaged. If you ever do receive a plane with issues, good luck on getting any resolution.
steph280 is offline
Old 02-10-2011, 09:34 AM
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A simple posting over at rcdiscuss.com tends to resolve such things quickly.
I've posted what to do in other recent threads.
Anyone with a problem should check that out...
But use:
- Persistance
- Restraint ( yelling never helps... )
- Patience
opjose is offline
Old 06-19-2011, 08:40 AM
Love To build
My Feedback: (30)
Love To build's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just ordered a set of retracts for the T-45 from Shulman Aviation. Here's the link http://shulmanaviation.com/product_i...oducts_id=1796
Love To build is offline
Old 06-22-2011, 07:20 AM
Love To build
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A little finessing of the electric retract, but do-able
Old 01-21-2012, 07:15 PM
Parman72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Herb,
I'm buiding the CMP T-45 from Nitro Planes.. Just wanted to find out what reinforcements you actually did in the retract area on the wing? Maybe I missed it on the forum? Can you re-post your images so that I can see what you have done??
Regards,
Greg
Parman72 is offline
Contact Us Archive Advertising Cookie Policy
