If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    Join Date
    Feb 2008
    littlestown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    50cc Kantana 85" (blue)
    I tried to install wing tube, it fits fuse. Will not go into wing tubes. The tube in the wings are cardboard and fit the alumn. wing tube very tightly. Is there a way I can lubricate the tubes to make them serviceable? I thought (was told by nitro) this was a new design however it seems to be an early design. I thought everone had done away with the cardboard tubes because of this problem. Please respond, Thank you.........Jim
  2. #2
    opjose's Avatar
    Join Date
    Nov 2005
    Poolesville, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 50cc Kantana 85
    I've resorted to putting a bit of sandpaper on a dowel to slightly enlarge wing tubes, when faced with the same thing.
    There is an art . . . to flying. The knack lies in learning how to throw yourself at the ground and miss.
  3. #3
    Join Date
    Feb 2008
    littlestown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 50cc Kantana 85
    opjose, Thanks for your response. I found a small bottlecap that is about 1" long and slightly smaller than the tube that I drilled a 3/8 hole thru stuck a 3/8 dowel thru the hole and filled the cap with epoxy, wrapped and glued sandpaper around it, cut the dowel to 18" and used it in my drill carefully....It's still tight but manageable....Thanks again. Jim
  4. #4
    Join Date
    Mar 2004
    milford, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 50cc Kantana 85
    bipeflr,
    how close are you to flying yours?
    is it this one?
    http://www.nitroplanes.com/giscka50arfn2.html
    would you recommend it? for the price it's hard to ignore.
    thanks,
    bart in NJ
    build fly rebuild
  5. #5
    Join Date
    Feb 2008
    littlestown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 50cc Kantana 85
    Barchiola, I wont fly until spring and it is not ready yet. The manual they send shows the other Katana except they list the flying weight as 17 lbs. and it feel it but I havent tried to weigh it. The joints seem to be glued lightly or not at all. I will use a DM 55 engine in mine but I had to cut the firewall back 2" and it was lucky I did as the firewall was keyed into the fuse sides but I pulled it apart without breaking anything(no glue holding it) So, be prepared to do more work than expected if you get it but if you are willing to do that then it can still be a bargin. On the firewall if I hadnt cut it back the carb linkage and needle valves would have been in the firewall and unassebale. If you have any other questions let me know. Jim
  6. #6
    Join Date
    Mar 2004
    milford, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 50cc Kantana 85
    thanks for the reply jim. i may try to find a good used hangar nine cap instead.
    enjoy your plane and happy holidays
    bart
    build fly rebuild
  7. #7
    Join Date
    Feb 2008
    littlestown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 50cc Kantana 85
    Okey dokey. Jim
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
