NitroModel Low-Wing Trainer 60 - 71"
NitroModel Low-Wing Super Aerobatic Trainer 60 - 71" Nitro Gas Radio Remote Controlled Airplane, can any body tell me what air foil this one has? Flat bottom or semi? thanks in advnce
sw1241
sw1241
RE: NitroModel Low-Wing Trainer 60 - 71"
sw1241 Date 2/13/2007 12:56:50 AM
sw1241
Date 2/19/2007 11:17:02 PM
Semi airfoil
Nitro Planes
So because of this post where nitro staff said that the super low wing trainer was a semi airfoil, my darling bride ordered for me for xmas, guess what, instead of a 71 inch semi,its a 69.5 flat bottom Explorer 60 L
Nitro staff, can i return this plane or can you exchange it for what i wanted?
sw1241
Semi airfoil
Nitro Planes
ORIGINAL: sw1241
sw1241
sw1241
http://www.nitroplanes.com/nilosuaetr60.html
Wing span: 71 in / 1800mm
Wing area: 900sq in / 58.1 sq dm
Flying weight: 7.2lb / 3300g
Fuselage length: 55 in / 1420mm
Airfoil: Flat Bottom
Engine Required: 2c 0.61 cu in
Radio Required: 4channels, 4servos
#1 Stang, you are right, all the times I have looked at that page, I never noticed the "flat bottom" note, I really need to get my eyes checked, I did however measure the wing panels on the top side they are 34 1/2 inches exact, each. thaks again for pointing out my short sightedness.
Merry Xmas to all
Merry Xmas to all
I just received this model also ... something to bang around while building "real" models. The wingspan is less than advertised, and is indeed flat-bottomed. Bizarre that NP's own rep answered the question incorrectly.
The "Explorer" comes with no fuel-proofing in the engine compartment (raw exposed plywood) - I primed and painted with Lusterkote. The joint where the wing leading edge meets the fuselage also has exposed plywood. I fabricated a balsa fairing and glued it to the wing bottom to close this gap (see photo). Covering match is Monokote Sapphire Blue.
I also reinforced the wing joint with 9 oz. fiberglass, and replaced the under-sized steel wingbolts with 1/4-20 nylon and new blind nuts.
When I e-mailed NP about the correct iron temp to get rid of the hundred or so bubbles in the covering film, I was told "this problem had never appeared before" so they didn't know.
Hoo boy!
PJ
Hoo boy!
PJ
ORIGINAL: pjwright
Hoo boy!
PJ
Hoo boy!
PJ
ORIGINAL: Mr67Stang
it is a 71 in wing or 1800 mm which converts to 70.87 in.
I've had one or two wings turn out to be slightly bigger than stated, and a few slightly smaller.
I'm not going to worry about that .13" difference though.
ORIGINAL: Mr67Stang
If you go to the NP web site and look at the specs on this plane it clearly says "flat bottom" airfoil.
The edges of the wing in the picture have enough shadow, that it seems that the edges are off the surface by a bit.
In lieu of more accurate descriptions I wish there were more detailed photos on the web site.
You can pretty safely start at the main spar for the CG ...
And if yours is still new, give it a shot of clear LustreKote if you have any hope of seeing the trim in place after a half-dozen flights.
PJ
PJ
ORIGINAL: pjwright
PJ
PJ
It's never been an issue with me, JW - but I'd sure like to hear from others.
After the initial wrinkle removal, I may see some mild wrinkles later in the season that come out with an iron held slightly off the covering.
Mind, don't soak the model with Lustrekote ... just a couple light coats to protect the seams.
PJ
PJ
My Feedback: (54)
NY
Hi, I just want to ask you if you model was a tail heavy, I'm using a TT pro .61 engine, and I see that I will be going to add a lot of weight in the nose [].
I juggled my equipment around, pejuve, and it balanced without adding lead with an Evolution .61.
I actually had the battery aft of the servo tray ... so I was a tad nose-heavy.
The biggest recurring issue was the main landing gear - I eventually rebuilt the torsion gear hold-downs with hardwood bearers and ply reinforcement.
PJ
PJ
I had a ASP 61 on the nose. I mounted it as far forward as I could. I put the battery under the fuel tank and got it balance right on the spar.
I too had to redo the main gear mounts and replace the nose wheel with a Dubro one.
I have a second one I built with (2) aileron servos, plus it is electric powered. She does fly really well.
Buzz.
Buzz.
The Buzzard's right - it is a sweet-flying plane once you work out the bugs.
Perhaps because it's a knockoff of the Goldberg Tiger?
PJ
PJ
My Feedback: (54)
NY
I'm finish the plain and I did the double servo aileron setup, I was wondering about the landing gear, I already improve the nose gear but I don't know what to do with the wings landing gears. If you could please post some pics of your to see how it looks.
Thanks PV
Thanks PV
I used 5/32 piano wire from the hobby shop. I just bent it to match the stock gear wire. Has been holding up nicely.
http://www3.towerhobbies.com/cgi-bin...?&I=LXR937&P=7
Buzz.
Buzz.
Pejuve - I snapped one main leg while I owned this plane, and it was a simple matter of bending new music wire to match the original. The bigger issue is the LG support structure within the wing. As built, mine had soft plywood bearers attached with insufficient glue. I removed these, and replaced with birch dowel drilled end-on to capture the torsion wire - braced in place with birch plywood epoxied to the spars. Then recovered the lower wing (2 rib bays) with Royal Blue Monokote (as I recall) for best color match.
Sorry - took no pictures of the surgery...
PJ
PJ
WA
This plane flies nice. Flat bottom vs semi semetrical = Semi flat bottom is what I would call it, mid way from the spar to the leading edge is curved on the bottom side.
Landing gear = garbage. The landing gear it shows in the directions is nothing like what comes in the kit. The main gear are shaped like the landing gear that mount on the bottom of a high wing trainer. Nose gear bent easily.
Bent my own gear out of 5/32 nice!
Engine mount = suposed to be for a .60 size, I don't think so, the mounts are too wide ended up rebuilding mine with carbon fiber much better and solid.
Make sure and re-glue everything you can reach, mounted .70 four stroke as far forward as I could, aluminum spinner, battery as far forward as possable, have extra electronics and batteries as well all mounted as far forward as possable still had to add 3 oz to the nose.
Upside its very stable and works very well as my UAV test platform.
