Go Back  RCU Forums > RC Airplanes > ARF or RTF > NitroModels Support
Reload this Page >
NitroModel Low-Wing Trainer 60 - 71"
NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Old 02-12-2007, 07:56 PM
sw1241
Default NitroModel Low-Wing Trainer 60 - 71"
NitroModel Low-Wing Super Aerobatic Trainer 60 - 71" Nitro Gas Radio Remote Controlled Airplane, can any body tell me what air foil this one has? Flat bottom or semi? thanks in advnce
sw1241
Old 02-19-2007, 06:17 PM
nitrostaff1
nitrostaff1's Avatar
Default RE: NitroModel Low-Wing Trainer 60 - 71"
Semi airfoil
Nitro Planes
Old 12-17-2007, 11:29 PM
sw1241
sw1241 Date 2/13/2007 12:56:50 AM
sw1241
Date 2/19/2007 11:17:02 PM
Semi airfoil
Nitro Planes
So because of this post where nitro staff said that the super low wing trainer was a semi airfoil, my darling bride ordered for me for xmas, guess what, instead of a 71 inch semi,its a 69.5 flat bottom Explorer 60 L
Nitro staff, can i return this plane or can you exchange it for what i wanted?
Old 12-19-2007, 01:41 PM
Mr67Stang
Mr67Stang's Avatar
ORIGINAL: sw1241
sw1241
If you go to the NP web site and look at the specs on this plane it clearly says "flat bottom" airfoil. A fact that the company rep is apparently unaware of. The specs also say it is a 71 in wing or 1800 mm which converts to 70.87 in. if the wing has dihedral it can easilly be that you are measuring the wing from tip to tip (as I would too) and they are measuring each panel and multiplying by two. Below are the specs as copied from the NP web site.
http://www.nitroplanes.com/nilosuaetr60.html
Wing span: 71 in / 1800mm
Wing area: 900sq in / 58.1 sq dm
Flying weight: 7.2lb / 3300g
Fuselage length: 55 in / 1420mm
Airfoil: Flat Bottom
Engine Required: 2c 0.61 cu in
Radio Required: 4channels, 4servos
Old 12-19-2007, 03:50 PM
sw1241
#1 Stang, you are right, all the times I have looked at that page, I never noticed the "flat bottom" note, I really need to get my eyes checked, I did however measure the wing panels on the top side they are 34 1/2 inches exact, each. thaks again for pointing out my short sightedness.
Merry Xmas to all
Old 02-18-2008, 09:24 AM
pjwright
pjwright's Avatar
I just received this model also ... something to bang around while building "real" models. The wingspan is less than advertised, and is indeed flat-bottomed. Bizarre that NP's own rep answered the question incorrectly.
The "Explorer" comes with no fuel-proofing in the engine compartment (raw exposed plywood) - I primed and painted with Lusterkote. The joint where the wing leading edge meets the fuselage also has exposed plywood. I fabricated a balsa fairing and glued it to the wing bottom to close this gap (see photo). Covering match is Monokote Sapphire Blue.
I also reinforced the wing joint with 9 oz. fiberglass, and replaced the under-sized steel wingbolts with 1/4-20 nylon and new blind nuts.
When I e-mailed NP about the correct iron temp to get rid of the hundred or so bubbles in the covering film, I was told "this problem had never appeared before" so they didn't know.
Hoo boy!
PJ
Old 02-18-2008, 03:04 PM
opjose
opjose's Avatar
ORIGINAL: pjwright
Hoo boy!
PJ
I answered this on the other thread you started.
Old 02-18-2008, 03:06 PM
opjose
opjose's Avatar
ORIGINAL: Mr67Stang
Yeah this is quite common. The measurements are crudely rounded.
I've had one or two wings turn out to be slightly bigger than stated, and a few slightly smaller.
I'm not going to worry about that .13" difference though.
Old 02-18-2008, 03:16 PM
opjose
opjose's Avatar
ORIGINAL: Mr67Stang
Maybe it's a "semi flat bottom airfoil" ?
The edges of the wing in the picture have enough shadow, that it seems that the edges are off the surface by a bit.
In lieu of more accurate descriptions I wish there were more detailed photos on the web site.
Old 05-12-2010, 01:11 PM
viperjody
anyone know the cg on this?
Old 05-12-2010, 01:52 PM
pjwright
pjwright's Avatar
You can pretty safely start at the main spar for the CG ...
And if yours is still new, give it a shot of clear LustreKote if you have any hope of seeing the trim in place after a half-dozen flights.
PJ
Old 05-12-2010, 01:55 PM
viperjody
the wings are joined, so I dont  know where the spar is... Any idea on the number of inches from the leading edge?
Old 05-12-2010, 01:57 PM
pjwright
pjwright's Avatar
The spar is located immediately forward of where the balsa sheeting leaves off - about 3 3/8" from LE on mine.
Old 05-12-2010, 03:07 PM
opjose
opjose's Avatar
And I'll second the Lustrecoat or Top Flight Clear Coat idea.
Cheap insurance to retain the look of the plane.
Old 06-06-2010, 12:02 PM
jw0847
ORIGINAL: pjwright
PJ
Does applying a clear coat of LusterKote effect the ability to heat shrink the covering later on if needed?
Old 06-06-2010, 12:08 PM
pjwright
pjwright's Avatar
It's never been an issue with me, JW - but I'd sure like to hear from others.
After the initial wrinkle removal, I may see some mild wrinkles later in the season that come out with an iron held slightly off the covering.
Mind, don't soak the model with Lustrekote ... just a couple light coats to protect the seams.
PJ
Old 03-18-2011, 03:11 PM
pejuve
My Feedback: (54)
Hi, I just want to ask you if you model was a tail heavy, I'm using a TT pro .61 engine, and I see that I will be going to add a lot of weight in the nose [].
Old 03-18-2011, 03:27 PM
pjwright
pjwright's Avatar
I juggled my equipment around, pejuve, and it balanced without adding lead with an Evolution .61.
I actually had the battery aft of the servo tray ... so I was a tad nose-heavy.
The biggest recurring issue was the main landing gear - I eventually rebuilt the torsion gear hold-downs with hardwood bearers and ply reinforcement.
PJ
Old 03-18-2011, 05:47 PM
blvdbuzzard
I had a ASP 61 on the nose. I mounted it as far forward as I could. I put the battery under the fuel tank and got it balance right on the spar.
I too had to redo the main gear mounts and replace the nose wheel with a Dubro one.
I have a second one I built with (2) aileron servos, plus it is electric powered. She does fly really well.
Buzz.
Old 03-19-2011, 03:40 AM
pjwright
pjwright's Avatar
The Buzzard's right - it is a sweet-flying plane once you work out the bugs.
Perhaps because it's a knockoff of the Goldberg Tiger?
PJ
Old 03-31-2011, 07:34 PM
pejuve
My Feedback: (54)
I'm finish the plain and I did the double servo aileron setup, I was wondering about the landing gear, I already improve the nose gear but I don't know what to do with the wings landing gears. If you could please post some pics of your to see how it looks.
Thanks PV
Old 04-01-2011, 03:27 PM
blvdbuzzard
I used 5/32 piano wire from the hobby shop. I just bent it to match the stock gear wire. Has been holding up nicely.
http://www3.towerhobbies.com/cgi-bin...?&I=LXR937&P=7
Buzz.
Old 04-02-2011, 07:03 AM
pjwright
pjwright's Avatar
Pejuve - I snapped one main leg while I owned this plane, and it was a simple matter of bending new music wire to match the original. The bigger issue is the LG support structure within the wing. As built, mine had soft plywood bearers attached with insufficient glue. I removed these, and replaced with birch dowel drilled end-on to capture the torsion wire - braced in place with birch plywood epoxied to the spars. Then recovered the lower wing (2 rib bays) with Royal Blue Monokote (as I recall) for best color match.
Sorry - took no pictures of the surgery...
PJ
Old 04-02-2011, 02:51 PM
pejuve
My Feedback: (54)
Thanks for the information, I got a 5/32 music wire from lowe's, also I will reinforce where the landing gear goes.
PV
Old 06-20-2011, 07:46 PM
chymas
This plane flies nice.  Flat bottom vs semi semetrical = Semi flat bottom is what I would call it, mid way from the spar to the leading edge is curved on the bottom side.
Landing gear = garbage.  The landing gear it shows in the directions is nothing like what comes in the kit.  The main gear are shaped like the landing gear that mount on the bottom of a high wing trainer.  Nose gear bent easily.
Bent my own gear out of 5/32 nice!
Engine mount = suposed to be for a .60 size, I don't think so, the mounts are too wide ended up rebuilding mine with carbon fiber much better and solid.
Make sure and re-glue everything you can reach,  mounted .70 four stroke as far forward as I could, aluminum spinner, battery as far forward as possable, have extra electronics and batteries as well all mounted as far forward as possable still had to add 3 oz to the nose.
Upside its very stable and works very well as my UAV test platform.
