Cessna 337-25
My Feedback: (540)
Cessna 337-25
Cessna 337-25 bought one of these on black friday sale...
Just what size servos are supposed to fit?
aileron servo pockets are tight on a Hitec HS-225BB mighty mini and Loose on Might Micro HS-85BB.
And for the Micro the notch to give clearance to the servo lead is so big the mounting screw is in free space!
Same goes for the fuselage!
For nose gear steering a nylon gear MICRO servo will not hold up to the forces endured.
RE: Cessna 337-25
I've found that if the servo is tight, or doesn't fit by a tiny amount you have the right one!
Just take a file and work off a bit of wood and you'll be good to go.
I don't have that plane, but I do have another .25 and you're right... don't use micro servos, use minis wherever you can.
