Extra 260 .50 Wing Tube Needed
I am in desperate need of a wingtube for my 53" extra 260 the aluminum metal tube.
I tried calling several times today so i could pay for it, i even sent a fax
edward
edward
RE: Extra 260 .50 Wing Tube Needed
One other note:
If you have the existing tube, or even a piece of it, measure the diameter.
You can then purchase an equivalent ( or maybe even stronger tube ) from many sources.
You want something identical in diameter, but it could be the same size in length or slightly longer.
You can always cut a slightly longer tube with a hacksaw.
If you can measure it, and post the dimensions, I'll help you look for a replacement.
thankyou, you have been more helpful tha np's customer service, they finally answered and i had to explain to him several time before he understood me, he they are out of stock on it
the outside diameter is 9/16 and length atleast 2 1/2 feet i was trying to fix the bend in the tube and i made it worse,
.5625 inches
.5625 inches
Found it.
K&S has "cut to length" ( you request how long you want it ) hollow alluminum tubing...
See: http://www.ksmetals.com/Cuttolength/chart.asp#RAT
[link=http://www.ksmetals.com/Cuttolength/chart.asp#RAT]Click me as an alternative.[/link]
Scroll down to the Aluminum tubing sizes.
They have what you need.
wow thankyou!!
well looks like the issue is settled, John of Nitrotaff pm'ed me that hell b shipping it first class uspd tomorrow, loooks like im gonna get to fly my extra this weekend
i have thought about it, but they dont give any warning signs, other than a snap...... ill just take it easy on the aerobatics, i think it got bent when i did a violent blender on high rates
Actually Stang's idea can still be used.
The aluminum tube is hollow.
If you wanted to you could insert a CF tube within the aluminum one, that way you would get the best of both worlds.
A CF tube is pretty light so this would not load down the plane.
