Go Back  RCU Forums > RC Airplanes > ARF or RTF > NitroModels Support
Reload this Page >
c-160 and mosquito twin engine planes...
NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Old 09-08-2008, 09:25 AM
matador_24
Default c-160 and mosquito twin engine planes...
Hello,
I am interested in either the C-160 or Mosquito, I see that both planes require 2 x .25-32 size engines....
Can I fit 2 x .46FX on them and expect a good performance??? or they are going to be just too heavy for those planes????
Old 09-11-2008, 01:24 PM
matador_24
Default RE: c-160 and mosquito twin engine planes...
A little help hereeeeeeee, I am actually planning on buying the plane but I would like to have some answers....
thanks
Old 09-11-2008, 01:30 PM
opjose
opjose's Avatar
You could get away with it, but why?
Two good .32 engines would provide more than ample power the plane...
The plane is rated for .25-.32 engines, of median power, so a set of newer ( more powerful ) .32's should do fine...
With 2 .46FX's you would merely need to move the battery back into the fuse.
Old 09-12-2008, 09:43 PM
matador_24
because I already have 2 spare .46FX......
Could you please suggest me the brand of .32 engines???? I really do not a lot about those sizes-performance....
thanks a lot....
P.S. If I use the .46, if I put some weight at the back of the plane in order to have it balanced with the extra weight of the .46... do you think it will perform great???? or better to get the .32????
Old 09-12-2008, 10:03 PM
opjose
opjose's Avatar
The FX .46 produces less power than say an AX .46, and they are a bit smaller too.
Since you already have the engines, just make sure that you can get them *****g out at about the same RPM's then put them on the plane...
As far as weight, put an extension on your battery pack and move it back in the fuselage, behind the canopy - IF - you have to, to balance the plane.
I'll bet you will not have to move the battery too much to achive the recommended C.G.
Old 09-12-2008, 10:15 PM
TooLow
TooLow's Avatar
Again, why over-power your planes? They are designed to fly within the range that the manufacture states. Would you put a 91 engine in a 30 size heli, same effect!
Old 09-13-2008, 12:53 AM
opjose
opjose's Avatar
He already has the engines, and they are both the lower output FX series, so he should be OK... plenty of power but not enough to rip the firewall out!
Old 09-13-2008, 01:40 PM
matador_24
exactly, I already have the 2 spare .46fx... and I have 0 .25-32 engine [&o]
I was concerned about the weight.... because for the power, I guess that if they are TOO powerful, I can just limit them to fly at 30-40% throttle........
can it be possible????
Old 09-13-2008, 10:08 PM
opjose
opjose's Avatar
Yes go ahead.
They will NOT be too heavy, nor will they overpower the plane by a wide margin.
Just be prepared to move the battery pack to adjust the C.G.
Old 09-14-2008, 11:11 AM
matador_24
cool, thanks a lot for the advice!
Old 09-16-2008, 01:38 PM
matador_24
Another question guys.....
do you think that for these planes (.25-.32) the OS .25 FX is a good choice???? or I would be better getting something bigger than a .25????? I have read very good comments about the power of the FX...
Old 09-16-2008, 02:19 PM
opjose
opjose's Avatar
Compared to more modern engines, the FX series is a little lighter on power.
That said it is vastly more powerful than the LA series planes.
The .25 would work, but the plane will not have vast amounts of power for verticals.
Old 09-17-2008, 11:08 AM
matador_24
thanks a lot for your help...... and I am sorry asking again.....
Now I have another option, a friend of mine is offering me for free his .36NT and I would buy just another one in order to use them both.....
Would the Evolution .36NT engines would work better for the mosquito and c-160?????
Old 09-17-2008, 11:55 AM
opjose
opjose's Avatar
Ugh I would avoid mixing a used engine with a new one.
You want two somewhat identical engines of the same vintage.
That way wear, compression and power will be about equal.
Old 09-17-2008, 12:34 PM
matador_24
ahhhh, hehe, my friend bought a little plane and it came with it (brand new).... it flew 4-5 tanks and crashed and destroyed the plane, engine is intact, since then (about 4months ago) he hasn't used it again
I believe it's pretty close to brand new...
but what do you think about the power??? .36 for a .25-.32????
Old 12-05-2008, 02:54 PM
multimike
The Mossie tends to come out tail havy, I fly a P38 with the 46s and they are awesome, they are not much bigger than the 25s and having an underpowered Mossie with that pointy wing is not a good senerio, I am just scratch building one now 72 inch wing span and will have Satio 72 FS in it Mike
