F4 Phantom Aileron linkage
Hi
I recieved my F4 Phantom over the Christmas season and I'm missing the two Aileron to servo, plastic threaded shackles". I assumed they where in the plastic parts bag the wheels, hardware and parts, etc where.
I searched through the box and other bags but not there. How can I get these two simple little parts or can I fabricate?
RE: F4 Phantom Aileron linkage
The provided CLEVISES tend to be fairly loose.
This looseness causes slop in the control surfaces, making it more difficult to control the plane.
Forgo them and pick up some micro clevises from Dubro.
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJGT4&P=7]Click me![/link]
The bronze part gets soldered onto the wire, and the plastic clevis gets screwed into that.
On the other side of the pushrod, use a "Z" bend if you are making your own pushrod though you should be able to use the provided ones.
You can also use something like this ( just make SURE you get the micro sized versions! ), which I prefer because it makes adjusting things so easy...
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD927&P=7]Click me![/link]
But a bit of blue thread locker is a must for those.
Opjose
Why couln't I remember that part name? Clevis.....
I had the same thought about fabricating two small threaded pins, and using cap-lock nuts to secure.
Very small, @.032"-.041".
Thanks for the link.
Tony
Tony
