Nitro Models.. Low-Wing Trainer 40
CA
I need the manuel or the CG position lost mine [:@]
http://www.nitroplanes.com/nilosuaetr40.html
Andrew
Andrew
MI
RE: Nitro Models.. Low-Wing Trainer 40
Some fellow who apparently works for Nitro responded to a member who needed a part. Maybe he'll read this and respond. Doesn't Nitro have a forum here on RCU? Check out the forums section.
Bill
Bill
CA
ORIGINAL: Ram Jet
Bill
Bill
Any one know?
Andrew
Well since this is a straight winged plane, you'd be safe putting the C.G. at the 20% to 25% of the wing chord length mark, measured at the wing root. This should occur IN FRONT of the landing gear anchor points... ( or your plane will sit back on it's tail! ).
It will probably fly all the way back to 33%, but I would advise against starting out with anything more than 25%.
If you really want to play it safe, and set it slightly in front of the 20% mark.
The plane will be a bit less pitch sensitive with the C.G. forward, and landings will be a bit hotter and vice versa with the C.G. back.
FL
Uh, I bought this plane, and nothing really seems to fit. I called customer service for nitroplanes, and they gave me a link to this thread... he said that a lot of people have been having the same problem.. Pushrods do not fit in the cheap tubing, I thought that the ends were just maybe crimped from cutting the tubes, but the diameter inside the tube is just too small.... Well now I see that this thread has nothing to do with that, and this threads been dead for 7 months... well maybe someone can help, or Ill just call nitroplanes back... I dont want to cut the monokote and replace the tubing, guess that guy was just trying to delay my problem so they wouldnt have to replace the plane.
Have you tried pushing a smaller piece of wire through the tubing to make sure it is unobstructed?
At worst you could flatten the tip of a long piece of wire and while turning it with a slow set drill, guide it down the existing tubing, to clear it out. Then you may be able to replace it with the Dubro stuff.
Cutting out a small flap back in the fuse, may let you guide your improvised reamer.
I've done this with a few planes when I've had problems with tubing.
FL
Yeah, I havent tried a whole lot yet, I was just going to see what nitroplanes had to say about it. Plane is pretty nice, you cant beat it for $55, but all of the hardware kind of sucks, like I said, nothing really fits, one of the tnuts in the firewall was trash, the bolt would just turn, like it was stripped, the aileron control bars were pretty bent up, which may just of been shipping, but the little things you thread on to the ailerons to hook up the pushrod to the servo was way too big, so that was just another thing to kind of put me down... Ill get it going, just seeing if anyone else had any problems with this particular plane..
