2.4GHz radio binding
The binding instructions with the radio accompanying my YAK-54 states that after succesfully binding "the indicator light will extinguish." I assume this is the red light in the center of the receiver. It does not "extinguish" but remains lit. Is this correct or does this indicate the radio is not ready?
CT
RE: 2.4GHz radio binding
My Spektrum flashes before binding then stays on steady after it is bound. Are you sure you read the binding directions correctly? What kind of radio are you talking about?.
Thanks for responding. My belief is that the receiver light should be lit but I need to verify that this is correct before risking life and limb launching this plane into the air. I hope it is just a bad attempt at translation but the instructions do state as I wrote, "3. If the frequency bind is successful, the indicator light will extinguish." This text appears under a photo of the receiver. In the photo there are no servos plugged in, just the power from the ESC and the "shorting plug".
