Tracking number
FL
Tracking number
I ordered an F35 edf from nitroplanes and unfortunately did not receive a coon of my receipt or tracking number due to email problems on my end. May I please have both of those items emailed to a different address?
Gabe Tuft
New email: [email protected]
Please let me know if further information is required for verification.
Thank you.
Gabe Tuft
Thank you.
FL
RE: Tracking number
I got it handled by Steve in the online chat section. Thanks anyways!
I do have a question about the F-35. It comes with a 25C 1300mAh battery pack. I have an extra 15C battery pack at home. Will that work with it or will the plane not have enough power? Will I experience servo failures?
RE: Tracking number
If I remember correctly that plane comes with an 1800mAh battery pack although the 1300mAh pack is what is listed, if memory serves me correctly ( note I MAY be wrong! ).
Even the included battery tends to run very warm to hot, so NO your existing pack will likely burn out.
I've flown this plane with a 2200mAh 20C pack after enlargening the battery cage ( removing the "bottom", not the hatch itself ).... and this was just about right... however an 1800mAh 20-25C pack seems to be the best combination between weight, speed and flight times.... ( about 5-8 minutes ).
