Go Back  RCU Forums > RC Airplanes > ARF or RTF > NitroModels Support
Reload this Page >
CMP Pro Marathon 20~24cc AEROBATIC AIRPLANE
NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Old 12-04-2012, 09:40 AM
  #76
captinjohn
Default RE: CMP Pro Marathon 20~24cc AEROBATIC AIRPLANE
I would by that Marathon....but first I want the wing I need for my Giles 202...they could ship them both together. But hey probably do not have either one in stock anyway............
Old 12-04-2012, 10:54 AM
  #77
opjose
opjose's Avatar
Captin.
CMP discontinued that Giles.
I've asked a few people if they had one but so far no luck.
I'd recommend you post a "wanted" ad here too. You never know.
Old 12-04-2012, 11:29 AM
  #78
tnt1106
I am selling my lightly used Marathon with JR126mg servos if any are interested. Local near Dallas Texas.
Old 12-09-2012, 11:38 AM
  #79
orck
Has anyone tried an RCG26 with this plane? I would like to see a close-up of the firewall, because the pre drilled holes doesn't seem to fit the ones from the engine.
Any upgrades while building? I think I am about to start the building.
Old 12-09-2012, 11:50 AM
  #80
opjose
opjose's Avatar
Don't worry about the pre-drilled holes.
Get some dowels. Cut plugs as close as you can to the thickness of the firewall and glue them in with epoxy.
Make absolutely sure the back side of the plug lies flat with the firewall's back as you will not be able to cut it down after the fact.
Once dry grind the front down until the plugs are smooth with the firewall.
Now drill new holes as needed.
BTW: I'm using a 26cc engine with this plane.
I believe it's a SV 26cc if I recall correctly, and is not a higher power 26cc.
While the plane flies very well, in retrospect I wish I had gone with a 30cc instead.
Old 12-10-2012, 08:12 AM
  #81
captinjohn
ORIGINAL: opjose
Captin.
Thanks for the help...maybe I will find one at a swap meet this winter>>>Perry Georgia !
Old 03-03-2013, 07:05 AM
  #82
Steam28
Steam28's Avatar
Selling a BRAND NEW in the box CMP Pro Marathonplane. I have one of these planes and installed a DLE-30. Will be listing elsewhere eventually. Price at Nitro is $187.20 and if you ordered (currently out of stock) from Nitro it would cost you about $25-30 in shipping. Local Pick up only, I can deliver to the Toledo RC show in April. Must be paid in full prior. My Price is $170. Thanks.
Old 03-13-2013, 11:09 AM
  #83
AMA 74894
Moderator
AMA 74894's Avatar
:-) I pm'ed you on the other forum...
consider it sold, I'm heading to Toledo to cover the event for RCU
ORIGINAL: Steam28
Selling a BRAND NEW in the box CMP Pro Marathon plane. I have one of these planes and installed a DLE-30. Will be listing elsewhere eventually. Price at Nitro is $187.20 and if you ordered (currently out of stock) from Nitro it would cost you about $25-30 in shipping. Local Pick up only, I can deliver to the Toledo RC show in April. Must be paid in full prior. My Price is $170. Thanks.
Old 05-07-2013, 05:56 PM
  #84
facab
I’m finishing my marathón, with some Little modifications on the engine (rcg26), I changed the cylinder head and added a HPI baja tuned pipe… I’ll let you know how it goes in the sky
ID:	1880079   Click image for larger version
Old 05-11-2013, 04:40 AM
  #85
captn conch
Why did you change the cylinder on the RCG 26? I noticed it does not have the angle plug. Maiden yet?
ORIGINAL: facab
Old 05-11-2013, 07:01 AM
  #86
facab
I didn’t change it, I modified it.
As at BDC the piston did not open completely the exhaust port I had to install an extra gasket in the base of the cylinder, but that will cause a reduction in compression ratio, so finally I decided to design a new combustion chamber with better design compared with the one it had before.<o></o>
ID:	1880996   Click image for larger version
ID:	1880997   Click image for larger version
Old 05-12-2013, 07:36 AM
  #87
captn conch
WOW!
Old 08-30-2013, 12:50 PM
  #88
AMA 74894
Moderator
AMA 74894's Avatar
I had almost forgotten about this thread... I DID buy the Marathon from Steam28 above, picked it up at Toledo.
I dropped a DLE 30 into it and this is becoming one of my ALL Time favorite airframes..
(close behind the Sukhoi 26 and Yak 54)
ridiculous vertical at half throttle.. yet floats like a trainer when you want it to.
ID:	1914827   Click image for larger version
Old 03-30-2014, 08:16 AM
  #89
AMA 74894
Moderator
AMA 74894's Avatar
this pic is for StAndBl (who bought my marathon...) (LOVE that airframe!)
best shot I've got of the muffler install.
Old 03-30-2014, 11:18 AM
  #90
StAndBl
StAndBl's Avatar
Thanks AMA. DLE definitely changed the muffler. Mine does not look like that. Time for a wrap around I guess.
Old 05-05-2016, 06:27 AM
  #91
hartenbos
hartenbos's Avatar
Hi Marathon guys...
I have been eyeing the Marathon for about 14 years now - and decided to purchase the last one available in South Africa from the Supplier. It was at first intended as stock for my Hobby Shop - but when it arrived yesterday ... I decided it was time I should become the proud owner of one of these.
I will be using a Super Tigre 2300 (3.7hp @ 12600). The engine & muffler (brand new by the way) fits inside the cowl and power should be ample.
I can't wait to get started with this little beauty.
Quick question ...
Is the Marathon loosely based on an Extra 330 or 300L maybe? I have tried to see if I could find a full scale Marathon but such does not exist. So I though it might be a derivative of ons of the Extra models?
Regards all & happy landings.
Old 05-26-2017, 08:40 AM
  #92
smkrcflyer
smkrcflyer's Avatar
I got one of these from a club member. Does anyone know what CG they flew these at? The number in the manual seams to make it tail heavy.
