Nitro Planes Formost 550 39" Pusher Prop Jet "Build"
My Feedback: (30)
CA
Formost 550 39" Pusher Prop Jet (White Version).
Strating My Formost Pusher Prop Build. Recieved My Formost 550 About 2 Weeks Ago Finally Open Up The Box All Parts Are There.
Kit Comes With Fixxed Gear, But I'll Be Adding Mini Retracts To It.
Here's Video #1 "Whats In The Box"
The Mini Retracts Does Not Come With The Kit.
[youtube]http://www.youtube.com/watch?v=ZIt2CcpAb7M[/youtube]
My Feedback: (30)
CA
RE: Nitro Planes Formost 550 39
No, I Just Enjoy Building Planes. I Like That They Have Fiberglass Planes And It Does Cost A Arm And A Leg. If You Really Look At All The Planes I've Done Builds On There All Fiberglass Planes Besides The Winter Time Foam Jets
why dont ya get the micro electric retracts from hobbyking?
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=10387&Product_Name=Digital_Servoless_Adjustable_Landing_ Gear_set__(Metal_version)
these are the big version u can get a smaller one as well for less 90$ including shipment to the usa
enjoy
enjoy
My Feedback: (30)
CA
Thanks For The Info I'll Look Into Those.
I'm Using These, Cause I'm Going To Have To Modify The Fix Gear Area Most Like Having To Remove Some Ply And Re-Expoy New Fitted Wood Blocks.
It's Going To Be A Challenge.
My Feedback: (30)
CA
I Finally Ca Glued All The Hinges For The Elevator, Rudders & Ailerons.
Then I Proceeded To Dry Fit All The Parts To Make Sure They All Fitted Correctly. All Parts You See Are Held Together By Screws No Epoxy Use Yet.
Next I'll Be Gett'n Some Hitec HS65 Servo's.
Here's Pictures.
Here's Pictures.
My Feedback: (30)
CA
In Video #2 Everything Has Been Ca Glued And Has Been Fit.
In Video #3, We Wi'll Be Installing The Servo's And Test All Control Surfaces.
[youtube]http://www.youtube.com/watch?v=jvxbAAUMaBQ[/youtube]
Flyboy:
I have not had a chance to view your videos on this plane... but I wanted to ask what retracts you are using in that picture above?
My Feedback: (30)
CA
Got Alot Done Today, Rudders, Elevator & Ailerons Servo Installed.
Aslo Manage To Finsh Installing The Mini Retracts.
Here's More Pictures. I Will Post A Video Later.
My Feedback: (30)
CA
Got The Maiden Flight In Today I'm Pretty Impressed.
The Maiden Flight Was Awsome.
For The Nitro Planes Formost 550 Pusher Prop Jet I'm Using A E-Flite Power .15 Motor W/ 9X7.5 Prop & E-Flite 60Amp Esc.
For Power I Used A 4 Cell ThunderPower 25C 2600mAH Lipo.
On The 4 Minute Flight I Only Used 1400mAH Out The 2600 Lipo Pack. So With This Setup I Could Easily Get A 6 Minute Flight.
Look For My Next Flight Here Soon.
[youtube]http://www.youtube.com/watch?v=0yEpOAJqI6c[/youtube]
My Feedback: (30)
CA
Put Another Flight On The Formost Yesterday
Having A Little Fun Wih The NitroPlanes.com Formost 550 Pusher Jet With My SkyCam. On This Flight I Only Used 1400mAH Out The 4 Cell 25C ThunderPower Lipo Pack.
[youtube]http://www.youtube.com/watch?v=cbJdEaoVQw0[/youtube]
MO
I'm a noobie to rc, but lots of time in full-sized planes. I've seen many of your posts and videos, and I just wanted to say that I admire your skill, tenacity and obvious passion for the hobby. Knowing that you like fiberglass kits, I was wondering if you had ever considered doing an electric conversion with this: http://www.nitroplanes.com/sese6070alra.html One of the most beautiful planes ever designed, IMO. I don't know if you're in to flying off water or not, but I think you'd be the guy to engineer and install scale retracts on this model.
MO
ORIGINAL: flyboytha1
Thanks Much .
Which Plane Is It? The Link Sends Me To There Home Page Click On The Planes And The Copy And Patse The Link.
Thanks Much .
