CMP P47 120 CG
MI
RE: CMP P47 120 CG
Ron,
I have the same plane and will be needing to balance it within a few weeks. Have you already balanced yours? Sorry I don't have an answer, you are further along than I am.
Jim
Jim
MI
RE: CMP P47 120 CG
Arebeck, did you balance your plane, and if so, what is your balance point? I am just now finishing mine. Based on calculations of 25% MAC, I have mine balanced at 110mm. But, that was after a lot of calculations and I'm not sure it is correct. I have heard that 95mm is a good point, but that seems too far forward.
Thanks, hope yours has flown successfully.
Jim
Jim
