NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
2.4Ghz F/A-18C Blue Angel EDF Servo problems
Reply
Old 08-21-2010, 07:01 PM
blueangel07
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 2.4Ghz F/A-18C Blue Angel EDF Servo problems
I recently purchased the model. I have glued all of the wings and binded transmitter and receiver. The throttle, elevators and rudder work fine, but the aileron servos wont respond to my transmitter. They start to fritz out and myleft wing servo is stuck in one position while the other one will fritz out. I am unsure of whether it is a wire that isnt connected well or if the servos are messed up. Also wondering if it might be the receiver that is the problem.
blueangel07 is offline
Old 08-23-2010, 10:55 AM
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 2.4Ghz F/A-18C Blue Angel EDF Servo problems
Switch your wires around, so that the ailerons are on the elevator and try again.
This will help you determine if the problem lies with the receiver or servos.
opjose is offline
Old 08-23-2010, 04:27 PM
blueangel07
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ive done that and they do the same thing
Old 08-23-2010, 04:30 PM
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure it did... But what happened?
Did the ailerons move CORRECTLY when they were plugged into the elevator channel ( indicates a bad receiver or transmitter ).
Did the ailerons behave exactly as before? Indicating a bad servo.
Are you SURE that there is enough power being supplied to the plane? Too little will also result in what you are seeing.
opjose is offline
Old 08-23-2010, 04:36 PM
blueangel07
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah they do the same thing as before. and the battery was charged for an hour , same thing happened.
Old 08-23-2010, 05:12 PM
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So it is likely that the servos are to blame.
Since both are reacting strangely, it could well be that the signal wire is being grounded, either internally on one, or via the "Y" cable.
Next try disconnecting one servo at a time, then start the plane, see if only one servo seems to work correctly.
If possible bypass the installed connector too. There is always the chance that a bad Y cable is all that stands between you and flight time.
opjose is offline
Contact Us Archive Advertising Cookie Policy
