NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Blue Lipo 1300
Reply
Old 08-31-2010, 11:12 AM
RCSNAPP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Blue Lipo 1300
Hello! I recently bought a dynam extra 330.. and in one of the drop down menues there was an option for an addition battery. I selected the option of the blue lipo 1300 mah battery, which was available at the time. I recieved the battery, but it does not have the correct connecter to connect it to my airplane. What do i need in order to connect this battery to the plane.. The connector for the airplane is a small two pin type...and the new battery has larger circular leads. Thanks for you help
Phil
RCSNAPP is offline
Old 08-31-2010, 11:17 AM
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Blue Lipo 1300
Basically you wire up your own connector or adaptor as you see fit.
I tend to make myself an adapter for each battery connector. This results in a small box full of adapters, but the advantage is that I only have to make ONE ( or two ) for each battery brand or type.
opjose is offline
Old 08-31-2010, 11:25 AM
RCSNAPP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, thank you.. Can you point me in the right direction as to what I need in order to make the adapter?
RCSNAPP is offline
Old 08-31-2010, 11:49 AM
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure...
You'll need something like this....
[link=http://www.nitroplanes.com/vemamoconira.html]Lead - Female - Click me![/link]
Or
[link=http://www.nitroplanes.com/vetamoconira.html]Link - Mail - Click me![/link]
And the battery plugs.... something like this...
[link=http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=10255]Bullet Connectors - Click me![/link]
Just make sure you obtain the correct gender for the JST ( small red ) connectors, and that you get the right SIZE of the Bullet connectors, as they come in various sizes.
I BELIEVE that pack uses the 3.5mm but I am not sure.
You'll also need a bit of heat shrink tubing, solder and an 25w iron.
opjose is offline
Old 08-31-2010, 01:12 PM
RCSNAPP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks!!
RCSNAPP is offline
Contact Us Archive Advertising Cookie Policy
