Dynam Hawk Sky issues
<font size="2">
order # yhst-1721025890263-168615 from Nitroplanes.com</p></font><font face="Arial" size="2"><font face="Arial" size="2"> My date of order was 1/4/11-I received around 1/8/11 roughly…I put the Dynam Hawk Sky together and went to adjust the throws…All is fine except the rudder. No matter how I try, it will cycle when the battery is plugged in and the transmitter is turned on, center for about 10 seconds (if that), and then go all the way to the right or left depending on whether the switch is set to reverse or not. From there it will not move. I also switched the plugs of the rudder and elevator and then the elevator does the same thing...It is my understanding that it is the RX and/or TX. I need to resolve this or get an RMA to return.</p> Thx,</p> Rob Cirnigliaro</p></font></font> |
RE: Dynam Hawk Sky issues
Hi Rob! I had the same issue with my hawk sky. In flight the elevator would get stuck and it would not stop looping. I went to fix it and found out the servo is bad. You will have to order a new servo. I suggest that you also order a better 2.4ghz receiver. This will save you a lot of time and money and possibly your whole hawk sky! Thats how i lost mine. Bad receiver. Hope this helps!:D
