RCU Forums
-   NitroModels Support (https://www.rcuniverse.com/forum/nitromodels-support-456/)
-   -   New F18 70mm edf (https://www.rcuniverse.com/forum/nitromodels-support-456/10379321-new-f18-70mm-edf.html)
wan2fly99 03-04-2011 04:58 PM
New F18 70mm edf
Would like to know what are the throws for the elevators and ailerons
Not listed on the plans
If anybody can help me out
opjose 03-09-2011 09:35 AM
RE: New F18 70mm edf
Set your low rates to have about 1/4" deflection and a bit more for your high rates.
Dial in Expo on your TX to avoid over-sensitivity.
I like higher roll rates so I set up more deflextion on the ailerons.
wan2fly99 03-11-2011 04:30 PM
Okay thanks will do
PS;
Did yu put ever try f18 with ruddrs is it worth putting them
Its a hassle to cut them out and hinge and then put rudder servo in
Dn't know if it is worth while
opjose 03-12-2011 12:01 PM
IMHO it's not worth doing.
You don't use the rudders when flying this plane, and because it will fly sooo slowly on landing ( under power ), you can land it width-wise on a runway during a cross wind.
