O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
O.S. 1.60FX Pusher
Reply
Old 03-09-2011, 05:24 AM
W.P. Hurst
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default O.S. 1.60FX Pusher
Bax, I am going to try the 1.60 in a pusher config. I will keep the tank close to the engine with the clunk facing back, and use large fuel line. I also have the stock muffler, will it give enough pressure without using a pump? What size 3 blade prop would work? I will have just over 9" clearance. Any other suggestions? Its the F-18 Hornet by Mike Pastro. Thanks
W.P. Hurst is offline
Old 03-09-2011, 07:02 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: O.S. 1.60FX Pusher
The stock muffler will give you plenty of pressure for the fuel tank. As far as a 3-blade prop goes, just take the 2-blade spec and either drop down one inch in diameter or one inch in pitch.
Now, the problem won't be to find a 3-blade prop, but a 3-blade PUSHER prop! Usually, a 3-blade prop won't work any better than a 2-blade prop, but it can help a bit with ground clearance.
Bax is offline
Old 03-09-2011, 07:17 AM
gadix
gadix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i had the same issue with a WEBRA 120 on a pusher prop jet flying king
http://www.rcuniverse.com/forum/m_93...tm.htm#9390149
howver the webra was with a pump so no issues with fuel
fule clunck facing the engine - hence - backwords!!!
i have got now a 15X8 pusher APC - i iwll cut it to a 13 size by length - this way i atill gain th epitch and rpm's and the prop wont scratch the ground.
gadix is offline
Reply
Display Modes
