O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
os 55 ax connecting rod problem
Reply
Old 05-09-2011, 09:16 AM
BAUTARCMODELS
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default os 55 ax connecting rod problem
hello guy :
last saturday I was flying my jackal 55 with a os 55 ax and a bannggg spinner one way and prop the other way I have a emergency landing I check the engine and the connecting rod broke on lower secction I'm using cool power 15% fuel and 10x8 apc prop the muffler is a evolution JETT and the engine is only been used 5 times,is any way os will cover this by warranty and were to send the parts,I been reading a lot about this and is a lot of people with the same problem on the os 55 ax.
any help is more thant welcome.
BAUTARCMODELS is offline
Old 05-11-2011, 06:08 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: os 55 ax connecting rod problem
Actually, there isn't a "lot of people" with the problem.  We just don't see seized rods with this engine.  I'd like to see the posts you mention.
When a connecting rod lets go like that, it usually means that the rod's lower end seized to the crankshaft.  That happens when there's not enough lubrication.  The lower-end seizes and twists off as the crank tries to turn.
We'd need to see the entire engine in order to make any kind of determinations.
Bax is offline
Old 08-22-2011, 06:51 PM
jasburrito
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use my 55 in an extreme flight chin yak. Have ran around 5 to 8 gallons through it. Noticed it making a little bit of a strange sound tonight. After inspection I found the rist pin seized to the rod. soaked in tranny fluid and got loose. Think it may have rusted or gummed. my bad. Gonna put back together and let eat.
but whatever
cheers
FYI If you cannot get your rod off crank pin it,s because the rods seized forward on wrist pin!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
jasburrito is offline
Contact Us Archive Advertising Cookie Policy
