O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS95 AX vs OS120AX
Reply
Old 07-10-2011, 10:42 AM
DanielOldani
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS95 AX vs OS120AX
Hi, I would like to have an advice here.
I´m starting a proyect of a Spitfire Mk 22 from scratch, it wil be an 1/6th scale, around 10 to 11 pounds.
I´m considering using one of these two engines, the price is similiar , so I made some relations between them based on the specifications.
The props would be 15 x 8 and 16 x 8.
Taking OS95 AX as "100" to compare:
Weight: 100 vs 114
Maximum power: 100 vs 106.9
Power/Weight (HP/Grams): 100 vs 93.77
Power/Displacement (HP/cm3): 100 vs 84.63
MaxRpm: 100 vs 60
Some other data I dont have would be fuel consumption at given rpm´s
What would be a better engine option in this case?
The refrigeration would be somewhat limited by the design (being a scale plane), as I´m considering the cylinder head will be inside the cowl. I will also use a Bisson in-cowl muffler.
DanielOldani is offline
Old 07-11-2011, 05:58 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS95 AX vs OS120AX
Either engine, once correctly propped, should be able to fly your airplane. You may need the 1.20 if your model comes out heavier than projected.
Bax is offline
Old 07-12-2011, 04:38 PM
DanielOldani
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bill, thank you for your answer! .
In fact the plane will probably be heavier, somewhere near to 13 to 14 pounds
Contact Us Archive Advertising Cookie Policy
