O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 55ax
Old 07-11-2011, 07:21 PM
tech1wi
Default OS 55ax
Whats the ideal RPM for an OS 55ax?? With a 12-6 prop I'm @ 12,750.
Old 07-12-2011, 05:53 AM
Bax
Default RE: OS 55ax
Mid-to-high-12,000's is a good place for full-throttle RPM on the ground when leaned to just rich of peak RPM. Your RPM looks right.
Old 07-12-2011, 06:22 AM
Augie11
Default RE: OS 55ax
How about 11K +/- using a 13x6? Or would you consider that too much prop for the .55?
