os 61 h wc start off fuel settings
The instructions for the O.S. Max .61 SX-H WC detail initial settings. You will have to then set the engine to the settings required by the heli/fuel/exhaust system setup you have. The settings will vary from heli-to-heli, and change slightly from day-to-day as the weather changes.
Here's the manual URL:
http://www.osengines.com/manuals/91sx-h-spec-manual.pdf
What fuel, exhaust system and plug are you using? This info is needed to get you in the ball park on the mid-range and high end needles. The low end you'll have to fiddle with on your own but thats the easiest one to get right.
