OS 1.6 FX Starting question
Hello,
I have an OS 1.6 FX with a Brisson pitts muffler and a Pro Zinger 18-8 prop. I also installed a perrry oscillating pump as per the manufacturers directions so I could put the tank on the aircraft's center of gravity. I also have the muffler pressure tap hooked up to the pressure line on the tank. I am also using a Du-Bro in line fueler.
I noticed others on this list seem to have excellent response to starting this mill. I was told to open the throttle, and cover the exhaust stacks on the muffler and flip it a few times to get a prime going. Motor is side mounted.
My problem is getting a good prime. I get fuel going up to the carburetor just fine this way, but it just runs out of the carb. I can't flip it fast enough by hand to draw enough fuel into the engine. This is really fustrating. Othwise the motor runs super. I just wish I could get it to start a little easier.
Thanks in advance for any help you can lend.
Rick
Rick
I use the regulating pump, so it pumps as you turn the engine over.
To get the prime into the engine, plug the carb. With cowling this can be a bit hard with your finger, but you can do it. I have a short piece of silicone tube, plugged at one end, which slips over the carb. I crank until I see fuel sloshing around in the tube, pull it off and then connect glow power. One or two backflips will have it running.
If I overprime I have to do a bit more flipping to get the mixture down to something that will start. With the exhaust port on the bottom it's easy to get the excess fuel out of there.
