O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
Powerbox Muffler and OS 61FX
Reply
Old 12-12-2011, 08:48 AM
thebluemax
My Feedback: (151)
thebluemax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Powerbox Muffler and OS 61FX
Hello Bill,
I have an OS-61FX that I got with a BCM Pitts muffler on it.The plane I am building now would look better with a stock type muffler on it instead ofthe pitts.
One of the guys in my club has a Powerbox Muffler from the 75AX he wants to sell me. The number on the muffleris E-4040. He says it should fit my 61 as they both have thesamebolt pattern.
My question is will this muffler be ok to run on this engine? Will it do anything to hinder the perfromance?Or should I try and get the stock muffler for it? Which I believe is the E-4010.
thanks for your time,
Bill
thebluemax is online now
Old 12-14-2011, 06:46 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Powerbox Muffler and OS 61FX
The E-4040 muffler has mounting hole of 42 mm between centers. The .61 FX has 43.8 mm between centers. The muffler will likely not fit without some modification somewhere.
Bax is offline
Old 12-15-2011, 11:02 PM
thebluemax
My Feedback: (151)
thebluemax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Bax
Hi Bill,
Thanks for getting back to me. I talked to my friend about what you said and he was adamantthat it would fit. So we tried to see if it would fit or not. Well she bolted right up to it with no problems. No mods were necessary to make it fit.I attached 3 pictures we took showing the muffler bolted onto the engine. I also attached a picture from the 61FX manual which shows the exhaust boltspacing at 42mm.
Will there be any performance issues or any kind of power loss using this muffler on this engine? Or should I try and geta e-4010 muffler whichthe 61FX manual lists.
thanks again for your time.
Old 12-16-2011, 06:57 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Since it fits, and is in the size range, it should work OK.
Bax is offline
Old 12-16-2011, 08:43 AM
thebluemax
My Feedback: (151)
thebluemax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sounds good. thank you for your time. have a good holiday.
ORIGINAL: Bax
Contact Us Archive Advertising Cookie Policy
