O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
O.F 25 F
Reply
Old 12-23-2011, 03:15 AM
James c harrell
My Feedback: (18)
James c harrell's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default O.F 25 F
I recently bought a bunch of RC parts from a guy who was selling out and found a brand new in the box O.S. 25F ABC. I was wondering about the type of fuel to use and how it would compare power wise to the modern 25s'. The only instructions that I have with it are for the 2b, 2ca,2cb,2cb-d,etc. "automatic carburettors"
James c harrell is offline
Old 12-23-2011, 05:36 AM
controlliner
controlliner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: O.F 25 F
It's equal to most modern .25's, the design is very much the same. The engine is an ABN design though, don't be fooled by the ABC designation and use 22% CASTOR OIL
controlliner is offline
Old 12-23-2011, 07:30 AM
James c harrell
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is abn? And I usually use Bryons 15 % nitro and 18% oil but I think they use a synthetic/castor blend.
Old 12-23-2011, 06:56 PM
controlliner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ABN = High silicon Aluminum piston running in a Nickle plated brass liner. Not as durable as a high silicon aluminum piston running in a chromed brass liner.
Old 12-23-2011, 07:36 PM
James c harrell
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will the 15/18 Bryons be O.K.? I ran it today on my Combat and she runs great. Better than any of my newer 25s'. Swings a 9-5 great. I never lean it out all the way and I probably won't. My combat plane pulls alot of Gs' and will cut most of my engines back if leaned out to the max. I run them all rich and deal with the clean up. I got a kick out of the carb instructions when they called the carb an "automatic" because it wasn't an air bleed.
Old 01-03-2012, 08:10 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
18% oil content would the the minimum. You should also have a significant part of the oil mix be castor oil. Non-ringed engines like castor as a major part of the oil mix.
Bax is offline
Contact Us Archive Advertising Cookie Policy
