O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
Prop Nut Loosens
Reply
Old 02-20-2012, 10:33 AM
Flysfloats
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop Nut Loosens
I have an OS .61 SF engine that has given me great service TILL now! I can not start the engine because the prop nut loosens up with the first or second flip of the prop. I am running Cool Power 15%, I have added an abrasive "washer" behind the prop. I simply can not tighten the nut tight enough to prevent this from happening. Your help is despartely needed, Thank you. FF
Flysfloats is offline
Old 02-21-2012, 06:50 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Prop Nut Loosens
Usually, if the propeller nut loosens when the engine is running, it means that the propeller nut isn't tight enough. However, if the propeller cannot be tightened enough, you may need to try a different propeller. It may not be able to be compressed enough to hold the nut properly-tight. You may need an abrasive washer between the prop nut and the metal prop washer, and between the metal prop washer and the prop.
Bax is offline
Old 02-21-2012, 09:22 AM
Flysfloats
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bax:Another day and another frustrating attempt to start this engine. I switched to a wooden prop, put abrasive drywall grid washers on both sides of the prop, am not using a spinner so no backing plate, tightened the nut as tight as possible, AND even with just a small squirt of fuel into the carb and NO glow igniter, I flipped the prop over a few times and the nut loosened.
I then retightened the nut, finger over the carb and turned prop over to prime the fuel line, put a small amount of fuel into the carb, and then tried to flip backwards. Would get a small pop but no indication it wanted to run either direction.
I even cut small hatch marks on both sides of the prop hub to try and get more grip on the washer/nut. What is next???
Old 02-22-2012, 07:13 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You may need a new propeller nut or a new crankshaft. You could try using two nuts, but that should not be needed for most two-stroke engines.
Bax is offline
Old 02-23-2012, 07:30 PM
Flysfloats
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well good news, with your support I got the engine running today!! A tech from OS engines/Hobbico also suggested using Lok Tite. After using a Master Airscrew and wooden props, I went to an APC prop, added my abrasive washers, cleaned the threads, and added Lok Tite. Let it set up overnight and this morning got a successful start and run. I hope that this proplem is behind me. Thanks to all that responded. FF
Contact Us Archive Advertising Cookie Policy
