O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 46 rear bearing replacement
Reply
Old 02-22-2012, 08:36 AM
mustangman177
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS 46 rear bearing replacement
OK.. So I replaced the rear bearing in a OS 46 AX (Used boca bearings on this). Upon putting the engine back together, I notice that the prop is slightly harder to turn over than from normal. It doesn't have that "Pop" when you turn it over from compression. It turns over easily, but feel some resistance.
What do you think ? Crank shaft is fully seated in engine. Have not run it yet, just want some feedback it this acceptable and ok to test run the engine.
Cary
mustangman177 is offline
Old 02-23-2012, 05:41 AM
mustangman177
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS 46 rear bearing replacement
No Problems with the bearing replacement. Test fired the engine and it ran fine. Put 4-5 flights on it and it responded well to all throttle settings.
Was just a little worried that I did not get the crank properly positioned when re-assembling ? The prop turned over alot easier after the first flight.......Probably just had to break in properly and loosen up.
Cary
Old 02-23-2012, 06:41 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like you got it licked!
Bax is offline
Reply
Display Modes
