O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 55AX Noisy
Reply
Old 04-21-2012, 05:38 PM
dgerhard
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS 55AX Noisy
When flying aroud half to quarter throttle i get a noise that sounds like lots of knocks. Some guys say it sounds as if it detonating but the noise is normal. from another post i read was wondering if the same applied http://www.rcuniverse.com/forum/fb.asp?m=9831530
dgerhard is offline
Old 04-23-2012, 06:05 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS 55AX Noisy
The LA-series of engines do not have crankshafts supported by ball bearings. The AX-series of engines, do. You cannot get noise from the same source. The crank of an AX-series engine should not move around. If it does, then the bearings could be bad. Usually, though, in mid-to-low throttle settings, you get additional exhaust noise caused by unburned fuel exiting the engine and burning in the exhaust port and/or muffler. It will vary, depending upon the exhaust system, fuel used, and propeller. It's common on larger engines, but not unheard of with engines as small as the .55.
Bax is offline
Contact Us Archive Advertising Cookie Policy
