O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
front seal drips
Reply
Old 06-30-2012, 08:16 AM
tazzzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default front seal drips
New 61fx,leaks ARO after sitting a while, just broke it in,runs fine,only 2 tanks of fuel run thru. no play at all in shaft,,is this a normal occurence? Also, where is the low speed needle valve located,,manual doesnt show where it is.
THX TAZZZZ
tazzzz is offline
Old 07-05-2012, 07:03 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: front seal drips
If you put oil into the engine after running it, and you then store the engine nose down, you'll get oil dripping out through the front bearing. That's because the front bearing really doesn't seal the engine. The seal is caused by a film of oil between the crankshaft and crankcase between the carburetor and front bearing. The pressures inside the engine force oil to the front bearing while the engine's running. There's a small channel in that area to help suck back excess oil. When the engine's running, a small amount of unburned fuel will come from there, but there should be no spraying.
The idle mixture adjustment for the .61 FX should be in the center of the throttle arm. It looks like a small slotted screw.
Bax is offline
Contact Us Archive Advertising Cookie Policy
