O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
After Run Oil into a 4 Stroke
Reply
Old 08-03-2012, 01:23 PM
KW_Counter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default After Run Oil into a 4 Stroke
Bax,
What is the proper way to inject after run oil into a 4 stroke engine?
Most carbs seem to be pointing down. Not as easy as a 2 stroke.
How much oil should be injected?
If the engine is cowled, are there alternate methods that can be used?
May I reprint part or all of your sticky on use of after run oil in our clubs newsletter?
Sincerely,
KW_Counter
KW_Counter is offline
Old 08-06-2012, 06:22 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: After Run Oil into a 4 Stroke
You inject after-run oil through the crankcase breather. You do not go through the carb.
1-2 tablespoons' worth would be plenty.
Bax is offline
Old 08-08-2012, 05:05 AM
KW_Counter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I inject through the breather will the oil get up to the valves?
KW_Counter
Old 08-08-2012, 06:16 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oil will work its way to the valves if you move the engine around while you turn the propeller. Eventually, some will get there...or you could remove the rocker cover and apply it directly. Usually, though, getting after-run oil to the valves isn't as important as getting it to the bearings. The bearings are what corrode fastest.
Bax is offline
Contact Us Archive Advertising Cookie Policy
