OS FS 200 & 200FI
OS FS 200 & 200FI
Bax
Dont know if you have any info yet but I see tower hobbies have the OS FS 200 as being available sometime
in april. Do you have any additional info on when the 200 FS fuel injected version might be available.
Just fishing, dont want to go YS
Elmer Fud
Elmer Fud
RE: OS FS 200 & 200FI
Hi,
on my new FS200-P I messed up the correct setting of camshaft gear to crankshaft screw gear. My intention was to give a few drops of oil to the camshaft before initial break-in run. During pulling the camshaft case lid with its tiny bearing, the camshaft little pit popped up and lost its setting on the crank gear.
The small mark on the camshaft gear is clearly visible.
How to set it back in correct order?
thanks
Dominik
thanks
Dominik
