O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS52FS Idle Adjust
Reply
Old 10-04-2012, 11:00 AM
KW_Counter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS52FS Idle Adjust
Bax,
My OS52FS, 40N Carb, was running superbly until a hard landing in the weeds.
Now it won't transition from low to high.
The pinch test indicates the low end is to lean, dies instantly.
I am guessing something is clogging the air bleed hole.
I can't find the air bleed; where does the low end air enter the carb?
The diagram I have found does not indicate the low end adjustment
screw or the air intake.
[link]http://downloads.hobbico.com/evpl/osm/ev44281000.pdf[/link]
Thanks for your help,
KW_Counter
KW_Counter is offline
Old 10-05-2012, 06:03 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS52FS Idle Adjust
There is no airbleed hole. The carburetor for your engine does not use an airbleed hole for idle mixture adjustment. There is a small screw next to the needle valve where you adjust the idle mixture. The air enters the carburetor through the venturi. On the exploded diagram of the carburetor, part #4, nozzle assembly, has the idle mixture adjustment.
If the engine won't transition from low to high, you'll need to check the entire fuel system to make sure it's OK, and then get the engine properly set. If a fuel passage has gotten something into it, then you'll have to clean the carb.
Bax is offline
Old 10-05-2012, 06:10 AM
KW_Counter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bax,
Thanks!
KW_Counter
Reply
Display Modes
