O.S. 21VG(P) roto-start question???
So, i am building my HB D8 Atsushi Hara Edition and I chose 21VG(P) ABL as my engine for it. But what i am concerned with is that if i can start the engine with a JP-2 pipe and a roto-start without anything getting in the way with the roto-start mechanism. I was afraid that the manifold will block the hole which the roto-start is going in. Any help will be appreciated. Thank you!
RE: O.S. 21VG(P) roto-start question???
We're not familiar with the car or how the parts integrate. When you put components from various manufacturers together that are not stock parts, you usually wind up with a bit of "fiddle and fit". If the manifold blocks access to the rotostart, then you have to either use a different manifold or modify the car to allow you to use the starter.
