Kano Sili Kroil with Silicone
NC
Hey bax would this be a good Lubricant for after run oil ?
Kano Sili Kroil
http://www.kanolabs.com/penLub.html#anchor174712
I currently use Red ATF But i was just curious if the Above Lubricant would work as well or if not better.
Kano Sili Kroil
RE: Kano Sili Kroil with Silicone
Based upon the manufacturer's description of the product, we could not recommend it. Among other things, that product will loosen corrosion. Corrosion products are highly-abrasive, and would start causing damage the very next time you went to run the engine. Any kind of "penetrating" oil should not be used as an after-run product because they will loosen corrosion products and let them be distributed throughout the engine.
