O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
0% Nitro fuel on AX engines
Old 10-08-2013, 01:35 AM
falcon_56
Default 0% Nitro fuel on AX engines
As I get ready to break in a .55 AX engine, I read in the manual the recommendation of 5-15% nitro fuel.
I was hoping to use plain 20% castor oil / 80% methanol fuel.
Is there a problem with using fuel without nitromethane on this engine?
Old 10-08-2013, 07:17 AM
Bax
That won't be a problem. Just use a hotter glow plug. An older type A3 or the newer #6 plug will help out a lot. People all over the world fly O.S. engines with zero nitro in the fuel. The oil content is much more important! You blend will be very good for the engine.
Old 10-08-2013, 08:21 AM
falcon_56
Great!!!
I have an OS #8 plug, but will look for a #6 and give it a try
Thanks for the prompt reply
