O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS FS 91II P (with pump)
Old 06-20-2016, 08:12 AM
jlrskymaster
Default OS FS 91II P (with pump)
As you know this is a discontinued engine, and it has suffered some damage during a crash. The problem area is the fuel pump regulator (on the back of the carb). The plastic cover was cracked, and I replaced it (very inexpensive). When I reassembled the regulator cover and ran the engine, I discovered that the plastic regulator housing had an edge chipped away, such that fuel was still allowed to leak out. I have been unable to determine if I can get the plastic housing so that I can reassemble the regulator and get the engine functioning again. I don't want to buy a whole new carb; the cost exceeds the value of the engine.
Can you help please?
Thank you.
