O.S. 1.08 FSR carburetor overhaul
CA
I need to replace the 3 small "O" rings on the carburetor mixture control valve for the 7D carburetor on this engine. What kind of oil or grease can I use to aid re-inserting the mixture control valve back into the carburetor rotor, that will not damage the "O" rings? Is Marvel Mystery Oil compatible with silicone rubber "O" rings? Thank you for any tips you can offer!
Ed
Ed
