OS FS-91SII: clunking sound when cab passes the push rod?
OS FS-91SII: clunking sound when cam passes the push rod?
I have two OS FS-91SII and one of them makes loud noise, after push rod reaches the top position, i.e. cam passes under the push rod. I've opened the cam cover and saw plenty of lubrication there. The bearing in the cover seems ok (I haven't completely disassembled the engine and can't see the bearing on the opposite side of camshaft).
What can cause this clunking, axial movement of the camshaft?
I have never run 4-stroke engines, only 2-stroke ones, and this puzzles me...
Thank you for your advise,
Boris
Boris
Loose valves would be my guess. A loud tappit sound is very typical on older VWs with air-cooled flat-4 engines. But like flyinwalenda said it depends on whether the sound is there when engine is running or not.
> Are you hearing this noise while it's running or when rotating the prop by hand ?
When rotating the shaft by hand, no how slowly.
Seems unlikely: the sound happens when the valve is maximum open, just after the push rod starts receding from its top position (and the cam passes the cam follower of that push rod).
Some people suggested that excessive wear of cams or followers might cause this, so, I've disassembled the engine at took these pictures. All looks good to my inexperienced eye...
Thank you for all your suggestions!
Boris
Boris
