OS 120 FS Question
OS 120 FS Question
Hi
I have a old OS 120 FS pumped. Pulled out of retirement to go on a Gaintscaleplanes Katana ARF.
I can't remember how the fuel lines hook up to the pump.
Specifically the bottom most nipple,where should I run this fuel line?
Bob
Bob
RE: OS 120 FS Question
The FS-120 Surpass with pump has three nipples on the pump:
"IN"--from fuel pickup in the fuel tank.
"OUT"--to carburetor
"R"--return line to fuel tank. This should dump to the forward bottom of the tank.
Your tank will also require a vent line that goes to the forward top of tank. Fill the tank through the fuel line or the return line.
