O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
FX91-What fuel tubing size?
Old 11-17-2003, 05:14 PM
4sylvester
Default FX91-What fuel tubing size?
I just purchased an FX91. I will be running it with the stock muffler. I have seen some threads where some users recommend a pump with this engine. I plan on setting up the engine and fuel tank per OS specs "without" a pump. What size fuel tubing does OS recommend for this engine? Std 3/32 or Large 1/8?
Old 11-18-2003, 10:26 AM
Bax
Default RE: FX91-What fuel tubing size?
You can use either. The 1/8 size will require you to use hose clamps on all fittings.
