OS FS 48 Surpass
My Feedback: (8)
WA
OS FS 48 Surpass
Hello Bax I have a 48 Surpass I bought on Ebay, and boy does it need some work I know this engine has been dicontinued. Is it worth sending in for service? Are there still parts available in plenty for this engine? I would work on it some myself if you told me the best way to get the piston liner out lol. I don't want to damage it.
Happy holidays
Brian
Happy holidays
Brian
My Feedback: (8)
WA
RE: OS FS 48 Surpass
Already tried that. I could not get it to budge, what should I use to persuade it? Also I took the screws out of the cam cover, but it would not budge either. Is there some trick to that as well?
Happy holidys
Brian
Happy holidys
Brian
If the cylinder liner's stuck in the case, then you may have to heat the case to free it. Sometimes carefully prying it up from below also helps. You need to make sure you don't 'ding' the liner.
If the cylinder head bolts are so tight you can't get them out, then the only solution may be to drill off the heads. We've had to do that on occasion when the hex heads get stripped. Make sure your hex key is new and sharp, and is the proper size. Only metrics will work, and you'll need a 2mm, 2.5 mm, and 3mm keys for most engine work.
