Old OS Max .10
Old OS Max .10
Hi everyone, I have an old OS engine, it says 10 and Max on the crankcase (Don't know if they made OS MAX back in the early 80's, that's why I ask about this). The problem is, it doesn't have a needle valve, and I would really like to use this little engine. Does anybody know if there's a substitution for the needle valve, or if another carb. will fit this engine? Any tips on where I could get a replacement N.V. and on how to use it?
IL
Old OS Max .10
Hi Jim! OS has been around since well before the 80s! ....
This will probably help identify your engine..http://www.osengines.com/history/ostimeline01.html
Those old engines which we know we have parts for are listed in the parts listings at:
http://www.osengines.com/parts/discontinued.html
http://www.supertigre.com/parts/index.html
If your engine is not listed here, we have little or no information available to assist you.
These gentlemen rebuild old motors and stock large quantities of older engine parts. Either of them may be able to assist you:
1) Preferred means of contact: PetesRC @ aol.com.
Pete's Hobbies
1814 Nelson SE
Grand Rapids MI 49507
Fax- 616-245-3106
Phone calls will be greeted with an answering machine. Please leave Name, Ph No. and, preferably, what you are looking for:
PH 616-243-9149
(Please note that there may be as much as a one week delay in response time due to extensive travel to shows, swap meets, and FLYING TIME! Lucky them! :-)
2) Model Airplane Engines- Antique to current, to use, to get out of production parts off of, or general purpose. 1200 Engines on My list - Buy- sell-Trade! send 33 cent stamp to get list or write to:
Contact: Bob Boumstein/ HWC PO Box 94 Boystown NE. 68010
E-mail : [email protected]
Fax 24hours : 402-334-4173
Phone: WEEKENDS ONLY 402-334-8688 (messages returned on Sunday only!) No
calls before 9AM CSTor after 9PM CST
3) Gene Steinkamp
8773 Russet Drive
Cincinnati, OH 45239
4) PISTON RINGS ONLY:
For discontinued piston rings, try contacting Frank Bowman. He manufactures repro and current piston rings for our modeling needs. He can make standard and Dykes type rings. If he doesn't have the ring you need in stock, you send the piston and cylinder and he will make it then. prices are $7.50 up to $9.50. His work is of the finest quality.
Frank can be reached at [email protected] or 1-505-327-0696 ( 6pm to 9pm mst. weekdays) and the following address:
Frank Bowman
1211 N. Allen
Farmington, NM. 87401
5) Alternatively, you might try placing an ad on one of the internet lists such as rec.models.rc.***, www.rcuniverse.com and some of the many other r/c related sites to attempt to purchase the item which interests you. (Post in the regular engine's forum rather htan the ask the manufacturer's area)
6) You might try swap meets, club sales, estate sales that list hobby equipment, etc.
Pete's Hobbies
1814 Nelson SE
Fax- 616-245-3106
PH 616-243-9149
3) Gene Steinkamp
8773 Russet Drive
Frank Bowman
1211 N. Allen
