OS Max .21 VZ-B (P) rear exhaust engine
Hi there .
I have a buggy " inferno 7.5 Mp and its fitted with OS max .21 VZ-B (P) engine.. I have a roter started which cant rotate that gear ( down there at bottom of the car) to start that damn engine .. engine is hard to rotate...how to start ? engine is hard to rotate too. what to use to start .. tell me plzz please .. u know that craze for first time running ur newly purchased buggy .. i did not have it except for the dis appoint ment due to not knowing anything about running a buggy till now.. please educate me .. thanks and regards.
praveen
Hi there .
praveen
RE: OS Max .21 VZ-B (P) rear exhaust engine
Generally, with racing engines, you'll likely need to use a heat gun to loosen the engine a bit. They're tight so that you have a good compression seal, but they can be a problem to get started the first few times. Warm the engine up, and it will turn over well enough to start.
