OS 120 III pumped
OS 120 III pumped
I have run a few tanks of fuel though my engine now but it still seems rich low end and lean on the top end . Reading some of the other posts I will run though a few more tanks then borrow a tacko meter to set the needle valve .
One thing that I am confused about is the small screw next to the needle valve that sits in the carb regulator . Mine is set to 4 turns out . I’m not sure if this is supposed to be 2.5 turns to get it back to factory setting.
Thanks for any info
Thanks for any info
